Reallyvi see lots of types of helos from my house even if no airports near , lots.. included mil mi-26 as fire duty!!
BsYamato's rotors
Re: BsYamato's rotors
I know about the big noise, till few years ago the hc.4 group was located in the Sigonella base and often i see them (sometimes three mh53 at time) fliyng over the beach and sometime near to my house
Here two more ... Ec-135 and BK-177, yellow madness!
Both revell boxes but the 117are matchbox undercover mould
Asap the box'n'sprues and the updates
Yellow sprues just have that something !!
Heres Box'n'sprues of the two yellows
EC135
BK-117
The 135 is more detailed than the BK (old matchbox reboxed) but the old one have good point with detailed ip, also the subject is featuring from an RTL series about fliyng ambulance service, never seen in Italy.
The BK was started some month ago , then freezed til now, the few works done was to glue engines sections to the fuselage and tail subassembly
Other night glued needed pieces to procede interior paint. Some thinning work was done on the exhaust holes and same exhausts to improve realism
About same works on the EC135
As you can see the ec inners are more detailed than the old matchbox
Test comparative fitting
some lead added to prevent tail sitting
Last night some putty work to fill some extractor signs and after washing with alcool , a mix of vallejo primer, white and a little point of blue (then also black ..) to use as primer and main inner color with three layers done
EC135
BK-117 : heres i added some plastic sheet on the front ceiling before to paint.
out of the little BK add it's all out of box
At the next!
EC135
BK-117
EC135
At the next!
Last night finished interiors:
Out of few instruments painted with brush in the both central consolles , all are oob
Gloss and semi gloss to protect colors
BK-117
Ec-135: theres more details to paint respect the 117, unfortunately nothing can be seen after close fuselages.
At the next!
BK-117
At the next!
Are washes up next?
Really tiny washes was already done. keep in nind that these are Flying ambulancies
Yes, I did see the gurney...
Clear parts time:
Cut off the three windows par side from the single piece that revell moulded for the kit
Then all windows was sanded on the borders and painted in black (recucing inner white effect inner reflections and improve trasparency)
then glued with a mixture of vinil glue, water and black acrilic
Almost same on the BK117, but here windows are already in single pieces
And glued on fuselages (after also upper and bottom corner windows)
Now waiting for perfect dry glue and next step to fill possible gaps and improve strenght of fixed windows
At the next!
At the next!
