Revell 1/144 Dauntless and Wildcat
Re: Revell 1/144 Dauntless and Wildcat
Everything is looking great! However, have you already closed the "cockpit" of the Dauntless inside? Because your back seat should be facing the rear of the plane since the rear gunner sat there facing aft.
Looking forward to seeing more.
Facing rear—
Facing forward—
I hope these images are helpful.
Duke Maddog wrote:Everything is looking great! However, have you already closed the "cockpit" of the Dauntless inside? Because your back seat should be facing the rear of the plane since the rear gunner sat there facing aft.
The gunners seat was set in a ring mount. It could rotate around on the ring.
You da man for tackling this small of a project Borg!!! While I do enjoy looking at these small builds I would never do anything this small. Awesome stuff bud.
Wow... those are tiny!! :wow:
Paul
Post by Paul »
OK, Borg. Make sure that you have all the right wires and cables in the correct places. and don't forget to w9ire up that engine also..... :giggles:
Well holy cow! This is interesting!!
Thanks guys! The next layer of white is going on this evening. I will keep you posted.
C'mone with it brutha! :wink:
Thanks for clarification on the rear seat. I didn't know it could swivel.
