Eureka! Some overlap! See above. This kit and aircraft are amazing!! Thank you!Floki wrote:https://www.amazon.com/FOCKE-Famous-Air ... ref=plSrch
https://www.amazon.com/Luftwaffe-Profil ... ref=plSrch
https://www.amazon.com/Focke-Wulf-190-T ... ref=plSrch
Volume 1:2:3 are costly of this series my friend has them and they have alot of good info in them
https://www.amazon.com/Focke-Wulf-Fw-19 ... w+190+book
Again you are welcome. That first book you got I got that one used at a model show it was missing the decals but still a great book.
Mister you are one building machine!! Watching............
- Paul
Bruce, you have greater intestinal fortitude that I by building this kit (being limited run) However, I feel that you will do this justice. I do enjoy a 190 build. How far do you plan to go in detailing this plane?
Joe, Thanks so much for following. This means a lot to me. I am always following your projects and gleaning insights into pretty much everything. So, yeah!mustang1989 wrote:Mister you are one building machine!! Watching............
Paul, Thanks so much for your thoughts, because what you wrote ties into a theme for this build—to try to build out of the box. However, I do want to add any visible brake lines. I also think the wing weapons will be better suited as brass. Ditto the antennas. So, I already strayed off target. Also each time John Kim builds a Revi gunsight I get excited to build one in the same fashion. Maybe my theme is slipping even farther away from me, lol.Paul wrote:Bruce, you have greater intestinal fortitude that I by building this kit (being limited run) However, I feel that you will do this justice. I do enjoy a 190 build. How far do you plan to go in detailing this plane?
Project Details So Far - 1/31/19
- 1. Rivets, rivets, rivets on exterior surfaces.
2. Hub and Propeller - EagleCal or Henri Dehane.
3. National Insignia masks.
4. Accurate camouflage.
5. Cabling, wiring and brake lines.
6. Revi gunsight a la Maestro Kim.
7. Most important—finish it.
It looks like the moldings are accurate to the shape. I'm interested in about the gun sight you mentioned.
Nice work! I wish I had a warehouse to build all those 1/32nd models...
Gary
Gary
Kit resin partFloki wrote:It looks like the moldings are accurate to the shape. I'm interested in about the gun sight you mentioned.
Looks a lot like the Revi C type of gunsight to me. Squared off glass. My guess is this should be the Revi 16B gunsight for the A-1 Series.
Revi 16B
B/W Fw 190 A-1
Unfortunately the original b/w photo crops at the padded bar, but the written description definitely states that is the 16B. Any ideas which is correct? B or C?
Thanks, Gary. I know what you mean—I live in a small apartment, which means I have to keep only a few new, unbuilt kits as well as completed models.GAF wrote:Nice work! I wish I had a warehouse to build all those 1/32nd models...![]()
Gary
