B-25 Italeri 1/72
BsYamato
Re: B-25 Italeri 1/72
Post by BsYamato »
More update about the Doolittle Mitchell:
After final inner matt and clear on instruments , glued windows, cockpit pieces
Gled fuselage withouth significative problems , used some strange tool to align wings with danish and chinese technology help
After this i realize one of the windows was runed by too much glue , obliviously in the inner side, so i removed, polished , glossy clear and glued again trhought the cockpit
Another test for the nose wright ( and keep in mind that more weight is under the glazed nose)
Glued the nose and tail rudders, and the canopy.. some part ruined again with extra thin cement :bag:
All main pieces ready for sanding and putty
At the next!
Just curious, but why don’t you use a different glue for attaching clear parts? I know the clear parts glue types don’t have the same strength, but they do help cut down on the headaches of marred clear plastic.
This is excellent so far. I gotta get me some Legos!
I agree with Carlos; I only use cement for clear parts. I've found that the Micro Scale clear parts cement seems to be the strongest so far, although the Testor's stuff runs a close second.
