Commission Build for Bruce Cooper
Re: Commission Build for Bruce Cooper
jkim wrote:Looks great Duke. I hate to be the bearer of bad news but I THINK that the landing gear is reversed. The doors should be on the inner side, not the outer. Hopefully, removal and replacement won't be an issue but with all of those parts you mentioned... I'm nervous this is not the case.
Yup... the main gear is reversed... other than that, very nice work!
Thanks for the compliments guys. And thank you John for pointing out my error. I will see what I can do to fix this. I might just have to remove the doors and place them on the other side, but I'll see what i can do.
I just knew something was going to screw up on this! :headbang: :headbang: :Bur2: Now I'll probably break five other things as I try to fix this! :headbang: :headbang: :scream:
Stay tuned, I'll see what I can do.
Wheel hubs need to be on the outside so removal of the legs would be necessary. Small chance... were the gear glued in with CA glue? If so... debonder could weaken the glue bond. Hey... you could probably do the same with Tamiya Extra Thin. Put a dab of TET and let the glue soften before pulling the legs out.
Duke Maddog wrote:Stay tuned, I'll see what I can do.
Hey Mark - don't sweat it, you're in good company... Here's mine... :headbang: :headbang: :headbang:
Stuart, thanks for that pic. There must be something in the glue that makes us do things like that.... :hmm:
John, these gear were glued in with Tamiya glue so I'll try using the Extra Thin to loosen them up before removal. I'm still concerned about breaking at least five parts though; there's no place to really hold this thing now.
Stay tuned.
Handiabled
Post by Handiabled »
I have no doubt that you will overcome this. It looks fantastic! I’ll be interested to see how you beat this into submission
It looks great Duke and I have no doubt that you'll get her fixed up! :shoutout: :shoutout:
Thanks guys! I'll be getting to this soon. Been looking it over to see the best way to tackle it.
