Bandai TIE Striker
Re: Bandai TIE Striker
Impressive cockpit work! I'm taking notes for when I do mine!
- silentbob33
- Senior Member
Thanks guys! This is my first Bandai kit and I'm really impressed with the fit, especially for being a snap together kit. I was thinking about paint since assembly should be fairly quickly, and I've seen TIE fighters in blue, gray, and everything in between. I'm thinking of a pale blue-gray and settled on Model Master's aircraft gray. It looks about right to my eye.
On the Bench: 1/48 Encore A-37B Dragonfly
Aircraft Gray is a beautiful shade. It should work perfect.
- silentbob33
- Senior Member
Thanks Stik, I just have to cut a few more parts of the sprue and clean them up and then I can start spraying paint.
I finished the main construction on the fuselage (I guess that's what you'd call it?).
Nice work man! I myself was thinking of doing mine in Intermediate Blue, but Aircraft Grey does sound better.
- silentbob33
- Senior Member
Thanks guys!
Duke, I had it narrowed down to the aircraft gray and intermediate blue. I watched the Battle of Scarif again (it counts as research right?) and they looked more gray than blue. After I clean up a few more parts I'll be able to get her painted and see if it will look as good as I think
Sounds good. I'll have to go back and watch that battle again too.
- silentbob33
- Senior Member
Well, plans have changed. My first two choices of aircraft gray and intermediate blue won't work as I don't have enough of either color, and I'm not sure when I'll be able to get to a hobby shop. So I'll end up making due with dark aircraft gray from a rattle can. On the bright side, no one can show me a real one and tell me my color is wrong
- silentbob33
- Senior Member
I was able to get everything painted, sealed with a gloss coat and the 5 decals put on. I'm not overly happy with the color, but I don't think it looks too bad.
20190525_212541 by James Hicks, on Flickr
20190525_212600 by James Hicks, on Flickr
20190525_212627 by James Hicks, on Flickr
20190525_212613 by James Hicks, on Flickr
20190525_212613 by James Hicks, on FlickrOn the Bench: 1/48 Encore A-37B Dragonfly
