Tried that. No joy.Stikpusher wrote:Slice and pop... micro sol, or solvaset will work...
1/48 Revell SBD Dauntless
Re: 1/48 Revell SBD Dauntless
Try that Decal 2 in 1 from VMS at Michtoy.com....
https://www.michtoy.com/item-VMS-AX09-V ... _in_1.html
Hit em again!Medicman71 wrote:Tried that. No joy.Stikpusher wrote:Slice and pop... micro sol, or solvaset will work...
Micro sol works wonders! Medic don’t give up on her, she is looking like a gem beside the decal fighting you!Stikpusher wrote:Slice and pop... micro sol, or solvaset will work...
Messerschmitt 109 Addict
Well they settled down a little more. Some spots look like crap but can't do anymore to them at this point. Now time to start the weathering. Any ideas how to dirty it up? Not used to weathering one with all that raised detail.
Dry applications of light grey chalk with a bit of wet water (two drops of dishwashing soap per half cup water. Get those decals as light as possible. Then add red, brown and dark grey chalks to the underside. Follow that with brown ink to simulate oil leaks. I am advising you to stay away from enamel and oils and use water soluble media. Once that looks good, I would seal with Future then splatter with more ink at the wing roots. Final coat of UV Flat.
Yes! I'd love to know your process. Did you have raised or recessed details?
