Revell 1/32 Me 109G from 1990
Re: Revell 1/32 Me 109G from 1990
Okay, a question for y'all, or all y'all. This kit just gives general color call outs, like dark green, etc. I know the cockpit was generally RLM 66 and that is what I have sprayed it with. Would anyone have any pictures of the side walls of the cockpit? The kit supplies two pieces that are separate from the fuselage. I'd like to do a bit of detail, not much because my crayons are not sharp. Here is the instruction section....
found some that will likely do the trick.
pzl66
Post by pzl66 »
Here Lyle, you can find some good color references in here:
https://www.eduard.com/out/media/84143.pdf
Messerschmitt 109 Addict
Thank you for the picture, Bruce. I think I saw that one. I never get tired of looking at cockpit pictures. Something about all those buttons and things. This kit is a passive aggressive one, or I'm a klutz. I remember why I don't like the "action, moveable control surfaces" feature. One of the hinge pieces simply evaporated on the elevator. No biggie since i'm going to pose the control surfaces, but still. For now the tailwheel is safe, as it is a separate piece!
I do feel like I'm simply going through the motions, though. I guess it is because I can't breath because my nose is stopped up and my ears are pretty much closed up. Guess a doc visit may be in order.
Cut masks for the wheel hubs and taped off the rivet detail, hoping to save it whilst dealing with the seam. I feel like Eyore today.
Very Cool!
Walking away for a short while as I try to figure out how to get the landing sticks back in th groovy little holders for that ever popular ACTION feature. I took my time on assembly, taped them in position, cemented the piece that holds them. Took th3 tape off one side and the gear came with it. I cannot see how to get it back in place without some cutting at this point. No, having an in flight isn’t really an option as the gear doors are laughably undersized. Think not even close to filling the opening.
Fuselage and wings fit pretty well, so I am hesitant to apply the hammer. I have to retreat and thin’about it.
:hmm: put it on a base on it's belly - bend the props... instant crash dio! I'll send you one of my Spitfire to hang over it!
Always a thought! :whistle:
Would you be able to take photos of instructions? Is it possible to add a support piece?
