I like adding strip styrene ahead of time to reduce the gaps where needed. Test fit and sand until the fit is just right.
Mike,Medicman71 wrote:Milliput!!
This project is all Milliput, all the time.
Carlos,Stikpusher wrote:I like adding strip styrene ahead of time to reduce the gaps where needed. Test fit and sand until the fit is just right.
Good points! This is a technique I need to gain confidence using. My first layer of putty reveals a surface that will require still more putty...
A little 1,000 grit “sanding hopscotch” with the panels:
Kind sirs! This is quite possibly the toughest seam I have ever ever ever ever filled! Harrumph! Round 2 begins! Hopscotch is over! Harrumph! Gloves are off.
Hurrayh!
Looking very good!
Looking very good!
Re: 1967 Monogram 1/72 US Navy A-5A Vigilante.
Kari,
Thank you so much!
Posting a notebook page which is problematic as I am working approaches to the problem and I am not sure which one I am going to pick.
Target area:
Thank you so much!
Target area:
That's what I call a proper modeling adventure. A saga, maybe. You bring an intensity into the game not many people are capable of. You got your own style, Bruce. And I have to say that I really like it.
