Kari's Revell 1/32 Bf-110 C-2/C-7
Re: Kari's Revell 1/32 Bf-110 C-2/C-7
Man you got that right. That right there sho is purdy. :shoutout:
Thank you guys!
Nicely and properly waiting for better times..
Looking good Kari - Are you taking a break from it for a while?
Do I sense a time out call here? :hmm:
Those fabric seat belts have really become a bottle neck in the build.. a show stopper.. I just cannot get them to look good, to nicely comform along the seat.. :hmm:
I need to figure out a solution..
pzl66
Post by pzl66 »
Bahh, you will find a solution. Nothing stops the Kari factory, beautiful work. I could stare at the wheel wells all day, wish I had that skill!
Messerschmitt 109 Addict
Had to do something about this situation... Either putting the entire kit back in a box forever or then do something about the situation.
The main and only reason for the build-stop was those bloody textile belts...
I just could not get them to work so today I decided, "heck, this kits cockpit will be straight out of the box build", solving the issue in one go.
Of course, not an easy decision, but then again, should the entire build be punished because of missing harnesses ? No !
As a compensation of missing harnesses, i turned the rear gunners seat a little bit
So, back on the bench, Dragons Revells 110, next step being to join the fuselage halves... a milestone of a build in other words..
Good Decision - that cockpit work is far too nice to stick back in the box.
I've never had much ;luck with AM belts either - these days I either use decals or SB my own. I've not tired the fabric ones.
What Portman said!
Handiabled
Post by Handiabled »
Glad to see you back on this build again! Look forward to seeing more :grin:
