Bandai TIE Striker
Re: Bandai TIE Striker
Impressive cockpit work! I'm taking notes for when I do mine!
silentbob33
Senior Member
Post by silentbob33 »
Thanks guys! This is my first Bandai kit and I'm really impressed with the fit, especially for being a snap together kit. I was thinking about paint since assembly should be fairly quickly, and I've seen TIE fighters in blue, gray, and everything in between. I'm thinking of a pale blue-gray and settled on Model Master's aircraft gray. It looks about right to my eye.
On the Bench: 1/48 Encore A-37B Dragonfly
Aircraft Gray is a beautiful shade. It should work perfect.
silentbob33
Senior Member
Thanks Stik, I just have to cut a few more parts of the sprue and clean them up and then I can start spraying paint.
I finished the main construction on the fuselage (I guess that's what you'd call it?).
Hey that looks cool!
Nice work man! I myself was thinking of doing mine in Intermediate Blue, but Aircraft Grey does sound better.
silentbob33
Senior Member
Thanks guys!
Duke, I had it narrowed down to the aircraft gray and intermediate blue. I watched the Battle of Scarif again (it counts as research right?) and they looked more gray than blue. After I clean up a few more parts I'll be able to get her painted and see if it will look as good as I think
Sounds good. I'll have to go back and watch that battle again too.
silentbob33
Senior Member
Well, plans have changed. My first two choices of aircraft gray and intermediate blue won't work as I don't have enough of either color, and I'm not sure when I'll be able to get to a hobby shop. So I'll end up making due with dark aircraft gray from a rattle can. On the bright side, no one can show me a real one and tell me my color is wrong :wink:
silentbob33
Senior Member
I was able to get everything painted, sealed with a gloss coat and the 5 decals put on. I'm not overly happy with the color, but I don't think it looks too bad.
Image20190525_212541 by James Hicks, on Flickr
Image20190525_212600 by James Hicks, on Flickr
Image20190525_212627 by James Hicks, on Flickr
Image20190525_212613 by James Hicks, on Flickr
