Special request build, 1/48 La-5
- jeaton01
Re: Special request build, 1/48 La-5
сделано?
Bunch of wisenheimers here…
stand by for progress report…
It is indeed. The perfect kit for a speed buildStuart wrote:That went together well!
It’s getting there… by this evening I should have all the main construction donetempestjohnny wrote:That was quick
Medicman71 wrote:That's it? I thought you'd have it done already.
Sir, YES SIR!LyleW wrote:Mike, I was thinking the same thing. After all, he IS retired....
Coming along nicely, Carlos. But, let's pick it up a bit, okay?
скоро товарищjeaton01 wrote:сделано?
Да, очень хорошо. Но этот американский Бакару опасен. Дайте ему широкое причал.jeaton01 wrote:сделано?
This morning after the gym I sanded the fuselage seams after letting that dry overnite. Then I added the wings…
And then I added the chin radiator, main gear well center plate, and the tail wheel mount. I also added some strip styrene shims at the rear of the wing to fill a gap there
I had to putty some small openings in the wing front that are a carry over from the common La-5/La-7 molds that should only be present on the La-7. I’m letting those dry before I sand them and resume adding the last assemblies.
More to come later on…
LyleW wrote:Да, очень хорошо. Но этот американский Бакару опасен. Дайте ему широкое причал.jeaton01 wrote:сделано?
One ping only…
So basic construction is now done. All that’s left to glue in place are the usual breakables: landing gear, pitot tube, antenna mast, and the bombs…
All ready to start painting later this evening…
- jeaton01
One ping only…
Yes, very good. But this American Buckaroo is dangerous, give him a wide berth!
Da, Lyle!
But the model looks good, Carlos.
Thanks John. This is a fun little build.
Some things in here do not react well to bullets.jeaton01 wrote:Да, очень хорошо. Но этот американский Бакару опасен. Дайте ему широкое причал.jeaton01 wrote:сделано?
One ping only…
Da, Lyle!
Looking good, Carlos!
