John's 1/48 AVRO CF-105
Re: John's 1/48 AVRO CF-105
I think it's gonna be a 'she' since she is looking great already!
- jeaton01
Red and white make pink… it’s a girl!
Seriously though, it’s looking great John! Very inspirational work!
Very nice John. Man those are some spindly landing gear - not a carrier bird I take it.
Nicely done! Man, that gear look spindly and fragile, too.
- jeaton01
Thanks, guys. The gear is spindly but that's just Hobbycraft. If I were to do it right they would look a lot beefier as on the real thing, but my hope is to semi hide the fault with the gear doors. The landing gear is better on the updated kit but I worked on the nose gear mount to get a bit more height there, as well as to give it some strength, the pins that were supposed to fit into sockets weren't long enough to fit in the sockets. I shortened and put steel pins in the main gear to make the model sit in the proper nose high attitude. There is a close up picture of the real main gear up above in this thread.
Very nice!
That is looking fantastic! Super tidy work on the scheme, too.
- jeaton01
Thanks, Mike and Torben.
I think this one is done enough for me, it's been a lot of work on a kit that gives you less to work with than it could. It is the second kit Hobbycraft released of the CF-105 in 1/48 and is an upgraded version of the first. Which is to say that it has parts that often do fit to each other, unlike the first kit which I also have. That one has parts that just don't meet the part are supposed to and is generally just a poorer molding in many respects. I added a resin canopy set, ejection seats, wheels, and burner cans from Iroquois Models. The new burner cans were too shallow so I extended them with tubes to deepen the ducting. The canopy set afforded open hatches, although I did use some of the kit clear parts for the front windscreen and the second seat hatches. Decals were made for the instrument panels and side consoles based on photos from some books in my library on the Arrow. I made intake ducts from fiberglass moldings as the kit ducts were only 1/4 inch deep. Iroquois has announced an improved landing gear for this kit, but it is not yet produced and I have my doubts about that happening. If they do I might replace the main gear with them, but in the event I just added some rib detail in the gear bays and added some two part epoxy here and there. I shortened the main gear considerably to get the proper nose high sit for the model, I may have also lengthened the nose gear but may not have. I did lower where it fits in the nose gear bay, as a part of establishing a place to mount it securely as the pins on the strut were too short to reach the appointed spots.
The decals were from Canuck Models and worked very well.
The CF-105 was supplanted by the Bomarc missile, and it's spot was also filled later by CF-101B's. It was a big airplane. The F-101B is pretty large itself, but especially from above the CF-105 looks much larger.
