Jo-Han Dyno Don Maverick-More Engine Detail-12/17
Re: Jo-Han Dyno Don Maverick-Dash-04/03
Stikpusher wrote:The dash looks mighty fine! Is the steering wheel chrome plated, or did you do that with foil or by some other method?
Thanks Carlos! That entire steering wheel was kit chrome. I'll probably dry brush some dark brown/ black ground up pastel on the steering wheel ring to make it look a little more realistic.
Robbed the foot pedal assemblies from the AMT Mustang kit and cut the grossly over scale swing levers from the back of each pedal. Will be working on forming the replacement levers and mounting them next.
Re: Jo-Han Dyno Don Maverick-Updates-04/04
Got the mounts for the swing pedals mounted in last night so all I had to do this morning was adhere the pedals to the swing levers that I cut and formed last night as well and insert them into the drilled holes in the mounts. I'm good with this so......it'll be off to painting these and final mounting.
Re: Jo-Han Dyno Don Maverick-Swing Pedals-04/05
All your little improvements are starting to add up. Those pedals look much better! :shoutout:
Thanks Carlos. You've also gotta remember.....THIS is where it was at the beginning....
Joe, just marvelous work. Outstanding!
Thanks Lyle.
Finished this part up this morning by painting the swing levers and pedals. I also darkened the steering wheel wood just a tad...
Re: Jo-Han Dyno Don Maverick-Dash Complete-04/06
The improvement on those little pedals is ‘UUUUUGGGGE! :shoutout:
Miles past the OOB offering. Is the ProStock script a decal or did you freehand that?
Thanks Carlos and John.
John: That is an emblem / script from a Detail Master PE set. One of the liberties that I took with this car (and there aren't many on it).
