Zvezda 1/48 Bf109F-4 - DONE! (again) New Pics
wing_nut
Senior Member
Post by wing_nut »
Jimmy invited me to join in over here form another forum. have to be honest... didin't know about this one but I do see some familiar names I've not seen in a wile.
Happy to join the fray.
For this party I'll be using the Vector resin update set, less the spinner. That will be the Eagle Parts spinner which comes with a drill guide base to get the holes.
The spinners in order... Eagle Parts, Vector and the kit. The Vector and kit parts are a bit too bulbous and neither has the rivet detail the Eagle spinner has. I may just make the dimple a little more crisp. Also the F spinner has a tear drop shaped opening for the prop blades. Kit part-none, Vector-a bit too much and the Eagle part are just about right.
This will be closed canopy to just need to be able to see some rudimentary shapes inside. A scrounged through the drawer that collects all the stuff that doesn't get used up and found 1 set of Luftwaffe PE seatbelts at the back of the drawer. The engine is there for no other purpose than to hold the exhaust in the correct position. I left one of the kit pipes in place for the pic to see the difference to the resin updated pipes.
wing_nut
Senior Member
Re: Zvezda 1/48 Bf109F-4
Post by wing_nut »
I went through my collection of decal sheet and found 5 Bf109-F4's. I Like 'em all, have a couple favorites but I' put the final; decision to you guys. Cast your vote for which scheme I should use to finish the build. I'll tally them from here and other forums where this will be posted.
Yellow 6
7.JG.54 Winter '41 Operation Barbarossa. White washed but weathered with worn white and yellow.
Black 1
15.JG.51, Spanish Blue Sq., Russia summer '42
Brown 13
1.JG 54 Grunherz, Russia winter '42
V - 03
Hungarian Air Force, Eastern Front, Flown by Gyorgy Debrody.
Black 8
Unusual desert scheme devised by JG3 in North Africa.
1st of all, welcome wing_nut !
great start of your one-o-nine !
My vote goes to Yellow 6 ! Would be great to see a white 109
Welcome to our forum and the GB! The Zvezda F-4 is a good choice, maybe the most accurate F in any scale.
For me it's the Hungarian one, please.
Manny1943
Post by Manny1943 »
Good to see you in here...love those Zvezda 109Fs!!! Maybe they'll pop a G-6 as well since Eduard screwed their attempt...
I vote for Yellow 6...
CallSignOWL
Post by CallSignOWL »
heeeey wingnut, I remember you! :bye:
glad to have you join us!
Hi Wingnut! Nice to see a familiar name from another forum join us over here.
Good start on the Fiedrich, my votes are for the last two options, I have never seen those before.
Fermis
Post by Fermis »
Welcome! :kissing:
I dig "V-03"...just for something different, but "6" in a beat up white wash would be pretty damn cool!
Cool and welcome. Looking forward to this build. Yellow 6 please
