1:48 A3D-2 Skywarrier
I will show you a real big one, build 2013, started with the first kit I have seen in the hobbyshop. It is a excelent kit, nice details, good be not on every part but most of the time. The model is big, bigger than I thought and heavy, so the main landing gear broke not only one time. Thake care to the details of the a/c you build, more or less every one is differnet, the antenna and refueling probe and the rear gun, so better check the pictures of the one you make.
hope to see more build A3D´s.
Re: 1:48 A3D-2 Skywarrier
Wow! Another beautiful build from you Cherry! If I can ever find one of these for a price that I can afford I will take up your hope to see more here challenge. Thanks for the heads up about the landing gear. Sounds like some metal replacement gear struts might be in order.
