Spitfire Vb italeri 1/72
BsYamato
Post by BsYamato »
One of lots of kits under work but not yet posted.
Started about a month ago.
Almost correct kit with some difficulty to build propertly.
Box'n'sprues
Kits invluded the american version and cut wing tips version but i'll go with the boxart version
First step cleaned the cockpit and glued nose parts for better fuselage fitting
filling walls with some structure
ready for paint, cylinders went from the kate or sonia...
original seat and cockpit
aluminium stripes on rudder pedals
glued more pieces and added rear details
IP is good too, only added some hole and scratchbuilded a new thinner side acces door
gunsight added with an extension and a new square glass (not the one in picture... after i'll show it :? )
Removed original wells and thinned the borders
tried to add a grill to the larger radiator inner
A plastic strip to close the upper air intake hole
added walls and new structures to new wells
And glued wings
The kit also included two versions of propeller , these ones are for the british version
Starting to paint with italeri acrylics
And finished with drybrush and washings
And before to glue fuselages
After i glued the gunsight forward because was too close to the cloche
And glued main pieces
After three layers of azure 89 and white
Three layers of darkened humbrol 94 and two layers od 29 brown
And the actual state with three layers of humbrol 29
Cut out original gears compass and scratchbuilded new ones
And painted with wheels
tht's all for now :)
At the next!
Re: Spitfire Vb italeri 1/72
That is amazing! Beautifully done.
That's totally amazing work on what I've heard is an old dog of a kit. The interior scratch building is as good as ever, as is the painting!
well done!
CallSignOWL
Post by CallSignOWL »
wow, those additons are stellar! way to go
BsYamato
Post by BsYamato »
Thanx guys, waiting to have some significant update to post more, actually painting the canopy after glued the fixed parts
BSY, what do you do for your day job? Micro surgery? I am always stunned by your small scale scratch work. :wow:
Stikpusher wrote:BSY, what do you do for your day job? Micro surgery? I am always stunned by your small scale scratch work. :wow:
I think he builds nano-bots
BsYamato
Post by BsYamato »
:rofl:
My work is 3d modeller for architects ... PC renderings i do :)
Virtually and not modelling all the day
dmminiatures
Post by dmminiatures »
Nice work in progress Silvio. I particularly like the transformation of the cockpit's interior from nothing to "something" with all the strips and gizmo. it looks convincing!
Monty / dmminiatures
BsYamato
Post by BsYamato »
Thanks Monty :)
Rotating wips as my usual today going with spitfire and Su-2 , about same steps, post shading and highlights on the bottom color
At the next
