Beriev Be-2 Amodel 1/72
BsYamato
Post by BsYamato »
So.. yesterday tried to post the storch resume and fail (my fault.. closed the posting windows after finished to write :evil: ) then try with this :|
box'n'sprues, you know it's a short run
as you can see theres some flash ... just some
A brief resume
After digging works to find the pieces trought the sprues modified the gluing order to keep the engine for last
removable
Original details of cockpit that erased after
adding cockpit details with stretched sprues and electrical cable wires and evergreen sheets
Painted. Used italeri acrilics to allow me to paint in the actual little workbench :| not bad these colors with brushes
before to close halves
wings after sanding/orbital sander cure
filled tail trenches
bottom wings and fuselage secured
and filling gaps
removed the wing bumper, not present in the version i'm building
under tension of regular maskin tape
rigging with stretched sprue
paint the bottom (after grey primer , enamel humbrol for external paint) with humbrol 89, 3 thinned layer to get a good surface
omit the light green steps (116 humbrol) and here actual situation :) a 91 dark green humbrol darkened with 33 black, also wires painted in black and done a brief drybrush
next step retouches to prepare for final steps :)
Sorry for the too miuch pictures on a single post :geek:
At the next!
Re: Beriev Be-2 Amodel 1/72
Yay!!! It's back!! Really looking great BsYamato!
Bsy is back, things start to get back to normal!
BsYamato
Post by BsYamato »
:D
as other four planes on my painting table he need few works to finish but i can't access so frequently as before :|
Goodie, more fun from BSY! Love to watch these take shape.
BsYamato
Post by BsYamato »
Thanx Lylew, last two day done a layer of glossy clear coat on the storch and the D-510.. and two layer on the beriev
next time decals on it :)
Glad you could bring this WIP over, BS!
Looks good, pal.
BsYamato
Post by BsYamato »
As promise decals, not so good but worked, replaced original sheet number "2" with "1" , the two was too lrge and ruined during the operations
Beriev Be-2 di silvio petrolo, su Flickr
this kit is not almost finished as other kits at the same point, more scratchbuild to do before to get dust with other finished models :?
At the next!
I like how the camouflage colours get "pushed" by the gloss coat.
