1:48 Fokker D.VII
1:48 Fokker D.VII
more biplanes, yes, the D.VII is was a standard figher of the germans and some partner nations, differnet versions were build with lots of different details...a good object for a collection, and this is my first, two more are on work..
Eduard Dual Combo
Re: 1:48 Fokker D.VII
:shoutout: Very nicely done... as usual! :beau: I do like that lozenge camouflage.
the next Eduard is finnished
More little Fokkers to look at...
here is my next Fokker VII OAW (Ostdeutsche Albatros Werke) from Roden with Eduard Decals, the engine is part of the kit, the Roden decals are bad, no chance to form with softer only Montys trick with thinner and flat base worked , the green strips made with oil paint, sealed with Metal primer and fatted with Revell flat coat..
CallSignOWL
Post by CallSignOWL »
Those are some colorful little birds :beau:
That camo is wicked! Man you pulled those builds off beautifully!
Awesome builds!!! :shoutout:
