1/72 Airfix FW-190F-8
Fermis
Post by Fermis »
I will be building this one as the plane on the boxart....with a little help from Eduard!
Starting with the pit...
Overall construction is pretty simple...it is a 1/72 190! Only real problem is the nose/engine face overlaps the fuselage and needs to be sanded down. Wing/fuse join just aft of the wing root needs some filler and sanding as well.
I got ahead of myself and glued the wings up, making it impossible to use the PE flaps. Ordered another kit to swap out parts. While waiting on the new kit, I reworked the main gears(too long as provided)....however, this was less than good, so I broke out some aluminum and brass tubing, Tamiya tape and some CA and scratched a new pair. (Bottom one is unmodified kit piece, next up is modified, and the others are mine)
New kit arrived yesterday, so I got the wings done. Had to remove a LOT more plastic than the instructions indicated to get the flap parts to fit. Also drilled out some brass rod to replace the gun barrels and made a new pitot tube from brass rod.
The right tools make things easy...and in the long run, probably cheaper than buying a/m pitot tubes!
Re: 1/72 Airfix FW-190F-8
Makes me want to break out the Binford 9000 dual turbo, super-charged electron microscope with 5x diopter!
Looks might fine, fermis.
More and more like Airfix´s new box art! Thought this was it. Man, I was wrong! Look at those LG legs! :shock:
Fermis
Post by Fermis »
Thanks guys!
Did some painting today....
White camo will go on later...after the markings.
pzl66
Post by pzl66 »
Ooh such fine detail! Cant wait for the white paint!
Messerschmitt 109 Addict
This camo looks already finished! Beautiful! What colours did you use?
AIRFIXER
Post by AIRFIXER »
Stunning work so far.
Keep it up!
Fermis
Post by Fermis »
Thanks guys!
Thomas_M wrote:This camo looks already finished! Beautiful! What colours did you use?
MM enamels....RLM 74/75/76 w/ white added to each for fading effect.
Did some more painting...decided to add some mottling, to give a little more contrast after the white squiggles are done.
Probably good you don't do a lot of 1/32...they would probably just fly off. Another one, very well done.
Paul
Post by Paul »
Krazy, man.
