1/72 Folland F.1 Gnat - Special Hobby
Ok, let's try to make something about this little fighter jet from the 60's.
It will be a OOB build, no extras, I am happy if I will be able to finish this..
As some of you might have read, the little fellow had some adventures before it landed on my bench..
But here it is.. finally!
All in all it looks to be a decent kit.
Some testfitting with this bird gave some goodie-good vibes and I believe this smallie will be a really good one!
So the work started with the engine... In total 4 pieces (!) makes the engine, paintbrushed and "weathered"...
and then assembled into a tube.. :-)
The pit paintbrushed with RLM66, everything pretty tiny..but still some visible details..
Instrumentpanel is pretty complex thing, in total 3 pieces + 6 different tiny decals..
As BsYamato also noticed, you can build this kit with either open or closed canopy. But the decision needs to be made pretty early in the building phase. There are two differernt versions of the instrumentpanel, depending of the decision/selection.
I decided for once to build something with an open canopy...
Instructions tell to add about 1 gram of weight in the nose cone. I used lead weight for this purpose.. in total 1,35 gram, to be sure... :-)
In with the squeezed lead weights and some glue on top of it to stabilise them.
And finally the moment when the fuselage halves were glued together...
To get an idea of the size of this jet, here next to my half-ready F-18 C ..
Let's see what next!
Re: 1/72 Folland F.1 Gnat - Special Hobby
Following! :popcorn:
It is a Special Hobby kit so do not forget to test fit everything.....twice.
BsYamato
Post by BsYamato »
Follow the special gnat :popcorn:
nice works about the cockpit and high level of details from SH even withouth resins ... i hate resins :DH:
BorgR3mc0 wrote:Following! :popcorn:
Thanks Borg,
I must say the fit is so far excellent. There is even adjustment pins and holes (or whatever they are called) in the fuselage halves.. usually something that is missing in Special Hobbys kits. At least those I have been involved in..
Perhaps they have a new engineer designing the sprues? :-)
BsYamato wrote:Follow the special gnat :popcorn:
Thanks Bsy!
Looking good so far. I likes it.
Thanks Lyle!
Great start on what looks to be a nice little Kit.
I really like the Gnat - I've built the Airfix T.1 but I might get one of these to go with it.
:popcorn:
Manny1943
Post by Manny1943 »
I like the Hornet...
portman wrote:Great start on what looks to be a nice little Kit.
:popcorn:
Thanks Stuart!
It is a nice little kit, though the Airfix (mine has the product nr A01006) was also a nice little kit.
When comparing the level of details between these, I must say still Special Hobby is better detailed.
But yes, I recommend Special Hobbys Gnat, it's nice!
