I'm an idiot (but you knew this)...
Hi Gents,
Ok so I’m an idiot
I’ve just spent ages trying to get as good a finish on my Grumman Panther as I can with the aid of micromesh and a Rattle can of Gloss Dark Blue (not to mention the 6 rounds of filler and sanding to remove the seams) – I then ruined it by (wait for it) painting on Matt coat with a brush :headslap:
Obviously the answer to this is,
“Stuart Dude, Buy yourself and airbrush and learn how to use it”
and you’d be right. But in the meantime, can anyone recommend a decent rattle can varnish?
I guess satin would be a good compromise. I’ve used Humbrol’s Matt and Gloss varnish from a can, and they’re rubbish, so any other suggested would be cool.
Cheers
Re: I'm an idiot (but you knew this)...
Best stuff in town
source: officesupplies24.de
Mostly used by artists to seal their acrylic paintings. It's based on a non aggressive thinner and does not change the shade of the colours beneath. I highly recommend it.
CallSignOWL
Post by CallSignOWL »
testors rattle cans are my go-to for flat coats. Dunno if you can get them in the UK tho....
Manny1943
Post by Manny1943 »
Testers Dullcoat...
Fermis
Post by Fermis »
:that:
tigrazor
Post by tigrazor »
First of all Id like to say: No one is an idiot. Were all humans and humans make mistakes. Ask some pro modellers and youll get a laugh when they tell you some stories about how to ruin a model.
Yes, an AB is a very helpful thing and makes lots of works easy. In the end its your decision of course.
Marabu clear coat? Yes please! The figure modeller/painter in me says "very good stuff" - as well as the colors itself and the clear cotes too. If you want to make sure it doesnt ruin your model first choice is acrylics. And Marabu are. I use them very often.
Basic rules:
Enamel base + Enamel finish: YES
(read the instructions thoroughly and check twice if they fit together!)
Enamel base + Acrylic finish: YES
Acrylic base + Acrylic finish: YES
Acrylic base + Enamel finish - HANDS OFF!!!
tigrazor
Post by tigrazor »
Not generally spoken Jim, more in a "basic rules for beginners" sense. Had some issues too with enamel cote in the past - maybe Im a fool too. ;)
Which enamel cote is idiot safe, btw?
I have used Humbrol acrylic flat on my last few builds. It is very flat, only give the model a single pass or it will turn white. Should be easy to find in the UK.
Results:
So even if you have an airbrush a rattle can can still be useful.
