Glencoe Oeffag Albatross D.III (WIP)
Well a month or two ago my modeling mojo went real low. So I decided to get back in the game I would go do something that I had not done in a LONG time... a biplane. I have a lot in my stash, from nice Eduards & Rodens, to original Auroras and their clones/re-pops. After looking at all the ones in my stash I decided to start here, as I have not built a biplane kit since I was in Jr. High School way back when. My basic rule to self here was to use just what is in the box, although I would modify kit parts as needed along the way...
So here is the boxtop. For those of you who have never seen or handled a Glencoe kit, they are usually reboxings of very old kits from other companies, sometimes cleaned up or modified, with basic instructions, a very nice Scale Master decal sheet, and sold for a very inexpensive price. They are not for the fainthearted. As far as I can find, Aurora never issued an Oeffag Albatross D.III (Austrian built for those who are wondering), and they only issued the German built Albatross D.III. So I am presuming that Glencoe took the orginal Aurora molds here and added the parts needed to make the Oeffag version, as well as having the standard D.III part. To call this kit basic is an understatement. Although in all fairness, the original molds probably date from the late '50s or early 60s. Most parts beyond the fuselage halves needed filing, sanding, or shims to fit properly. Not to mention a good amount of flash on many parts. On the plus side the kit does come with a beautiful Scalemaster decal sheet with three marking options, which is probably worth the $5 or so that I paid for this challenging kit.
Of course, as usual for a build the first step once that I decided to build this crate was research. I did happen upon a walk around of a beautiful exact flying reproduction Oeffag D.III, so armed with this source I went to work.
Now in the cockpit I did deviate slightly from my no additions/kit parts only self imposed guidance. I did add a control stick, and I was not going to use the pilot figure, and teh kit did not include one. So from my spares bin I found something suitable. And I also drilled out some lightening holes in the seat based upon what I could find in online photos.
and I built the motor, probably the best molded and detailed part of the kit. I did drill out each of the exhaust stacks and filed the intake manifold to rounded profile rather than the as molded squared off edges.
Then these items and areas were painted
Next up was the cockpit & fuselage interior painting- varnished plywood, as well as some instrument decals (minimal) for the panel.
then painting of the interior and exterior engine areas that I knew would be best done before assembly, as well as the guns.
afterwards I glued the fuselage halves together with the cockpit in place, then added the engine, guns, and cowl/decking. The fit was very rough and required quite a bit of sanding before it finally began to look right. I almost felt like I was shaping a wooden model during this point.
more to come shortly...
Re: Gelncoe Oeffag Albatross D.III
Next up was the tail. The fit of the horizontal stabilizer was horrid! Basically the only part that made contact was the leading edge area and where the elevator met the fuselage rear. So I had to do some serious shim work and sanding to build it up to make for a proper fit.
But I was successful there and then with some putty, not bad at all.
Then I added the rudder and ventral fin/skid. Again it was a major case of test fit, sand, test fit again, file some more, repeat as needed.
Next up was adding the radiator to the upper wing. The bottom of those parts was dead flat and needed some serious file work to match the airfoils shape of the wing. I also thinned down the wing trailing edges and added some scallop shape to the trailing edges of the ailerons, based upon the walkaround photos. I also added some locator holes for the radiator lines to the lower portion of the radiator.
Now the attachment points for the lower wings are some of the weakest I can imagine. So I cut the pins on the wings off, drilled a locator hole in their place on each lower wing, drilled thru the fuselage locator holes, and added a length of .20 gauge steel wire to reinforce the wings. I then super glued the wire to the locator holes in the wing and used Plastruct cement (Very hot stuff, like Tenax) to attach the lower wings and set them aside to dry overnite. I also drilled locator holes for the radiator lines in the fuselage and engine
and finally, I added the interplane and cabane struts to the upper wing, aligned them as best I could, and set them aside to dry
So that is where this project stands at this point. I am just about ready to begin painting, after I mark and drill some attachment holes for the cabane struts in the forward fuselage.
Like I said, this is not a project for the faint hearted....
Fermis
Post by Fermis »
Agreed!
This plane...from above...looks like wings on an anorexic manatee!
Yes, the Albatross D.III & D.V were sesquiplanes, like many of the Nieuports. The lower wing is only half the chord or so of the upper wing.
CallSignOWL
Post by CallSignOWL »
yeech...dunno if I would've even continued with this kit. Nice work tacking this hunk of junk!!
CallSignOWL wrote:yeech...dunno if I would've even continued with this kit. Nice work tacking this hunk of junk!!
Yeah, I am not sure what I was thinking when I chose to start here, but... :hmm: But it is kinda fun to tackle such a beast...
Well, I have started painting. I have the wood and linen base colors on. Just need to let that dry then I can get the bare metal for the cowl and engine deck on before the camo pattern.
You're a brave man Stik - great work on whipping this kit into shape!
portman wrote:You're a brave man Stik - great work on whipping this kit into shape!
Brave or crazy? :hmm: and thanks for the kind words. I am doing what I can here.
Well here are the basic paint colors on so far. All Humbrol- Oak for the wood areas of the Fuselage, Linen for the fabric areas of the wings, rudder, and horizontal stabilizers, and Aluminum for the engine deck & cowl
and a rest fit of the upper wing onto the rest
next up over the coming days, applying a camo pattern
That is looking good. . . even with the good eye closed! Way to whip it into shape
