Monogram USS Ramsey
Monogram USS Ramsey
Well since we have no ship WIPs, I guess I will start one. This is the old Monogram box scale (roughly 1/300) USS Ramsey. Originally classified as a Destroyer Escort Guided Missile (DEG), her class was later reclassified as Frigate, Guided Missile (FFG). Anyways I am improving this old kit with some Gold Medal Modelworks Photo Etch, plus what I can scratch up to improve the general appearance of this old kit. (BTW, this build has been sidleined for a few years, mainly due to a couple of moves, but I feel the urge to complete her soon)
Re: Monogram USS Ramsey
So the first thing I did was add the bow sonar dome. There was quite a gap there afterwards so I filled it with some styrene shims and sanded them smooth.
Now I have the 1977 edition of "Ships and Aircraft of the US Fleet" as my primary reference, so using that I saw that the main radar was incorrect in the kit.. I ditched the kit piece and from various photos, I scratched up a SPS-52 radar using sheet styrene and some mesh from a Starbucks Green Tea bag for the texture
Then I built the Mack assembly (Mast & Stack), but the kit really simplified that compared to my references
so I began to do correction work
I drilled out the stack exhausts and added some aluminum tubing in their place
the top yardarms were orginally oriented for and aft, so I had to cut it off and change it to port/starboard, and add a small cap at the top. And I added the SPS-10 surface search radar from my GMM PE set, and various bits of PE that should be there according to me references.
Then I did some basic painting to the hull and superstructure- Hull Red and Black for the lower hull and Boot Topping, Neutral Gray for Haze Gray, and Gunship Gray for Deck Gray. I was told those were close if not equivalent to the USN colors.
Then I began cutting off molded on ladders and replacing them with PE ladders
Stik, thanks for making a lead into this chapter by starting the first ship WIP! Well, someone has to be the first! :)
What date is this kit? According to the box this was issued the first time in the 70´s? Two sprues and the hull? Maybe a good kit for a beginner, even when adding PE parts.
What glue do you use to get those tiny parts on?
Thomas, the instruction sheet is copyrighted 1973. And I am not sure if that is the original issue of this kit. There is also a kit of the lead ship in the class, USS Brooke. It may be a few years older. Yes It is really a great kit for the beginner, quite simple as a matter of fact. And that is why I chose it to be my first ship kit to try PE with.
I used Gator Glue to add all the PE. An acrylic glue very similar to Elmers White Glue in its' usage. I had heard good things about Gator Glue from fellow members of IPMS and AMPS at meetings of those clubs.
Man that's a lot of PE!! :o
It's looking great Stik!
