1/48 Tamiya/Eduard Fw190D-9 "Black 10" Her Last "Hoorah"
Seeing Texgunner's thread inspired me to post this one here that I finished up with in early 2014.
I started off with a Tamiya Fw190 D-9, cut the nose off and replaced what was missing with a Jumo 213 inverted V-12 engine/ mounting from an Aires engine / cockpit set. I used limited cockpit parts from the set due to the fact that I had a spare Eduard Fw190 A8/R2 kit to rob some awesome PE parts and detailed plastic parts from( Will get to that later). I also opened up one wing root cannon on the port side of the aircraft and used CMK's under carraige update set to display the tail wheel retracting mechanism through the access panel on the port side of the tail fin. The landing gear got a total upgrade due to Tamiya's inherent problem with the landing gear being WAY too short on these kits. I used the Eduard landing gear struts and doors from my spare kit to correct that issue. Also used from my spare Eduard 190 kit were the sliding canopy section (just a lot of detail in those things), the instrument panel(to include PE) , control stick, rudder pedals (PE), wing root cannon access panel and I ended up ordering a spare Eduard 190D-9 kit and using the cowl machine gun access cover out of it due to the fact that the Aires panel just literally sucked, but already ordered my replacement part to once again complete that kit and have another D-9 to build. The parts used from the spare kit were just too good to NOT use. Paints are Vallejo Air acrylic on the exterior and Model Master acrylics throughout the interior and nose section of the aircraft. All in all I had a good time with this build until it came time for the Aires engine access panels but I made it thought it ok.
Anyways here she is:
Re: 1/48 Tamiya/Eduard Focke-Wulf Fw190D-9 "Black 10"
Oh my goodness! Joe, it still looks as fantastic as I remember! Man, that is some beautiful modeling brother. Incredible to see all those opened panels. :shoutout:
Gary
Holy mackerel! You went all out in doing this using various parts from different Fw 190s. :bow: :beau:
What a plane, what a construction!
She is a Beauty with a big B, Joe!
More please! :-)
CallSignOWL
Post by CallSignOWL »
wow! would ya look at that....nicely done!!! :shoutout:
Thanks everybody! I've got another 190 build left in me yet. May go with an A variant in the foreseeable future....
:bow: :bow: :bow: :bow:
A Frankenwurger! :yikes: Very well done sir! :shoutout:
I used some excess Eduard & Tamiya parts to upgrade an Otaki 190A several years back... But yours came out much nicer! :beau:
gino b2
Post by gino b2 »
very nice !
gino
Thanks gino and stik!! Never built the Otaki version before. Is that a decent kit?
lawdog114
Post by lawdog114 »
I'm not sure how I missed this. Stunning work Joe. I have the Tamiya D-9 in the stash so thanks for the idears....
