Denmark cayuse - Italeri 1/72
BsYamato
Post by BsYamato »
Heres my first new wip of the year : the little italeri cayuse that will be in denmark markings.. in some way i'll try as i don't have the decals :giggles:
No sprues pictures (i think it's a notorius kit..) and i already started some work, as the rotor assembly and cockpit main pieces .
Going to rotor the kit have wrong spin direction, so i glued it upside down and replaced the control beams with stretched sprue
Glued missing pieces at cockpit
Le cloche assembly , removing ejector pins and copper wire to simulate IP cables
Spreading cables and cut'n'glue in place. Added details to the rotor head. the rotor cap is not needed.
Primer and after black (not pure black) painted
At the windscreen drilled two holes, closed after with plastic strip from inside
Drybrush
Complete IP
Cockpit too
almost done rotor
smashed lead as weight
After glued side windows with clear glossy vellejo used instead of glue , closed fuselage
Also the windscreen glued with clear glossy
Some rescribbing not yet finished
And more elements glued
At the next :)
Re: Denmark cayuse - Italeri 1/72
Wow! You blink once and suddenly it's ready for paint! Looking good so far...
What are you going to use for Denmark decals?
midnightprowler
Post by midnightprowler »
1 Corinthians 15:51-54
1 Thessalonians 4:13-18
Ask me about Speedway Decals.
Looking good BSY - It's a funky little kit that. I've built one and have the MD500 version in the stash.
Paul
Post by Paul »
Very nice
BsYamato
Post by BsYamato »
I'll solve this minor problem later :hmm: actually no idea
Stoppel makes an AM decal sheet for Danish cayuses.
https://www.aviationshopsupplies.com/hu ... art=123953
Nice work! I really like the last photo of the Cayuse sleeping on its side. Cute.
One of the best choppers ever built! You are most impressive in your speed and detail work here BSY. :shoutout:
I actually just saw a civil version of one of these flying yesterday. Quite near to where I was and low... not the later MD series with the "T" tail, but an early model like this with the "V" tail. I was surprised to see the type still around, and also had forgotten how much that it still appealed to me over far more modern choppers I see all the time here. A true classic.
Great looking build. Just bought one of the MH-6 kits with the T-tail
