The pilot sits low as if there is no chute under him. I carefully removed his head, drilled a shallow hole in his body, extended his neck with some stretched sprue, and stuck it back on, turned to his left. That adds a bit more life to him.
The cowling can be left off to show the engine, but because the parts are so thick this is more of a gimmick because it leaves the engine undersized to compensate.
But it has all fit together very well with only one spot of putty in front of the windscreen. But I suspect that was my error.
The first thing that struck me as unusual was the size of it lol. Why do 109's always look so much smaller than they should? Lol!
[image]http://www.use.com/images/s_2/a68f362d53edd0780c61_1.jpg[/image]
[image]http://www.use.com/images/s_2/a68f362d53edd0780c61_2.jpg[/image]
[image]http://www.use.com/images/s_2/a68f362d53edd0780c61_3.jpg[/image]
[image]http://www.use.com/images/s_2/a68f362d53edd0780c61_4.jpg[/image]
[image]http://www.use.com/images/s_2/a68f362d53edd0780c61_5.jpg[/image]
The pilot actually painted up nicely for such a tiny little fella. Not much to write home about in the pit. The pilot takes up most of the space so he became my focal piece in there.
[image]http://www.use.com/images/s_2/2282ae69630e6f0e29d3.jpg[/image]
Not the first time I've painted a 1/72 pilot, but this was the first time I put that much detail into one this small.
![Smile :)](./images/smilies/icon_e_smile.gif)
And once again I've gotten some primer on the model and that's where it sits for now.
[image]http://www.use.com/images/s_2/a6826c1de5c75306ffe6.jpg[/image]
I'll update as soon as something happens.
Thanks again for taking a quick look!
