HobbyBoss 1/48 MiG-31B Foxhound Completed
dmminiatures
Post by dmminiatures »
Hi Gents, here you go, the HobbyBoss version of the MiG-31B Foxhound. My first completed build for 2018, despite having done it the waning months of 2017. Happy to share it with you
My Verdict: A lower -than-average kit. It could have been a stellar of a kit if it weren't for some flaws, particularly the dreaded intake joint gaps. it had its high marks (white metal landing gear, thin decals, fine surface details). I have read great reviews and build commentaries about the AMK kit. It might be so that the HB version could be delegated as a down-grade alternative to the AMK. However, if a modeler can oversee the flaws and instead see the plus points of the kit, then it might be a great alternative to the AMK version.
The kit builds into a massive model. I compared it with Academy's F-16 Sufa in 1/32 scale and it almost matched its length. The weight of the model was quite heavy and a surefire to convince modelers that they need a white metal landing gear (something the AMK kit does not have)
Monty / dmminiatures
Re: HobbyBoss 1/48 MiG-31B Foxhound Completed
Stunning.....
Even if some issues with the kit, you have Monty made a stunning result! Just absolutely great build!
dmminiatures
Thanks, K Saarni and Tempestjohnny!
KSaarni wrote:Even if some issues with the kit, you have Monty made a stunning result! Just absolutely great build!
:that: :beau: :shoutout: :shoutout: :shoutout:
Like I said on FB: You turned s**t into gold.This is an incredible result.
And here's a recommendation for you HB engineers: Read the WIP and do better next time!
Monty, that is indeed one fantastic build. A beautiful big imposing beast of a Mig. There may have problems along the way, but looking at the finished build, you would never know it. :shoutout:
Congratulations! The photos are fantastic, too. Great detail shots and leveled framing. Such a pleasure to see your work!
:shoutout:
dmminiatures
Many many thanks for the support, guys. Very happy the drama is all done. I have learned a few new things and that is a blessing in disguise. Hopefully I can use it for my future builds.
Great effort in the build with great result!
