1:48 F-106A Delta Dart
you know the old Monogram kit, once with all open, the other parked with FOD cover and all closed
Re: 1:48 F-106A Delta Dart
A beauty indeed. If you don’t mind me asking, what is the dimension of the 1/48 scale Delta Dart? I’m debating whether to get in 1/72 or 1/48 scale. Looking to do one based out of Griffiss AFB from my area.
long 45cm
wide 25cm
it is in the dimension more or less like a F-15 Eagle
Another beautiful pair of Deltas CL! I like the different posings that you did with these two, open and closed.
BlackSheep214 wrote:A beauty indeed. If you don’t mind me asking, what is the dimension of the 1/48 scale Delta Dart? I’m debating whether to get in 1/72 or 1/48 scale. Looking to do one based out of Griffiss AFB from my area.
The Century Series fighters were all large aircraft, with the F-100 and F-104 being at the smaller end of the spectrum, yet neither as compact as a MiG-21, and the F-101, F-102, F-105, & F-106 all being quite large. Lots of engine, weapons, radars, and avionics packed into those.
Beautiful work, CherryLock!
Did you have any issues mating the fuselage halves particularly at the tail?
if you close the speedbrake you have work and filling.
the general join on the sides are ok, littlebit of filler and grinding, normal not a problem, and rescriping the lines :giggles:
You did a great job filling the seams and scribing new panel lines, CherryLock! Seriously! Wow!
:shoutout:
Congratulations!!!!
long 45cm
wide 25cm
Looking good CL... and it's big...
Very nice! Those are on kits are defiantly on my to do list.
