1:48 Breguet 14
1:48 Breguet 14
this is the kit from Hi-Tech, and the name is the only hi teck in the box, very poor shortrun with with metal and PE parts, qualety like Eduard in the beginning (1990) but in 1/48 there is only this kit
link to the instruktions
https://www.scalemates.com/products/img ... ctions.pdf
history
https://en.wikipedia.org/wiki/Br%C3%A9guet_14
it is aircraft of the American Expeditionary Force, 96th squadron, 1918 Nancy
Re: 1:48 Breguet 14
That's really nice CL!
Re: 1:48 Breguet 14
That’s another mighty fine looking build Peter! :shoutout: I see that you drilled some anchor points in the fuselage for rigging early in assembly and added the line at that time. What do you use for your rigging lines?
Re: 1:48 Breguet 14
Another superb bit of work!
Re: 1:48 Breguet 14
Very nice!! :shoutout: :shoutout: :shoutout:
Re: 1:48 Breguet 14
Stikpusher wrote:That’s another mighty fine looking build Peter! :shoutout: I see that you drilled some anchor points in the fuselage for rigging early in assembly and added the line at that time. What do you use for your rigging lines?
the rigging in the fuselage:
-dill the holes
-take the wire if posible like a U from hole to hole and glue with CA
the wire is nylon coil from a tailer shop, only for the shorter lines (stearing lines, short riggings on landing gear..) I use sprue
