1:48 P-51B “Spare Parts” (Tamiya Kit)
Cheers folks, thanks for stopping by!
Well, shoot... what’s there to say really? I haven’t had much luck getting projects off the ground lately. Black 1 Remixed crashed and burned. Not once, but TWICE! First due to orange peel on the yellow wing tips, second due to a misalignment with the motor causing the lower cowling to push out past the bottom of the top cowling part along the sides -and that was my fault for basically building the god forsaken kit in a manner which was an afterthought to the manufacturer. Seriously, do you know another jackass besides me who’d want to eschew the fantastic engine Eduard supplies with the kit in order to build the thing buttoned up?
Speaking of engines, I ended up terribly unhappy with Marga’s engine. The plumbing I did. So I began the process of removing it and refactoring it...
Look, here’s the problems:
1. I began all those projects when I was drunk. And having been sober now for over two months, my vision has shifted dramatically.
2. I had AMS. That’s not an issue in and of it’s self, but let’s face it- I’ve got a long way to go before I’m an “advanced modeler.” A lot of that custom work was substandard.
3. My methodology for doing things like painting, weathering, etc. has changed.
4. I can actually see myself and my work objectively now.
My wife told me a week or so ago “Babe, I’m sure all those old Renaissance masters have projects they never finished. At least you learned something. Why not carry over what you learned into something you’ve never done before? Something unfamiliar to you instead of trying to get back into it with the same old subjects?”
Makes sense. My confidence to work on my jet was dead. And the old Messerschmitt E3’s and even Corsairs just weren’t doing it for me. I want to start, and complete, an airplane. A WWII airplane. A cool WWII airplane.
So I broke out that old P-51B kit I’ve been planning, and immediately set the ground rules:
1. Build the kit out of the box with the exception of two things:
a. add a safety harness, of which you have a spare you aren’t using
b. use aftermarket decals because Tamiya decals and I don’t necessarily get along
2. Try a bare metal finish
3. Do not worry about correcting kit faults with scratch building or aftermarket. I still need a lot of practice working with resin. I suck at it. I can add a little bit of wiring if I want but that’s it. I’m competent to do that. I’m not competent with working with resin. If I want to work with resin, use a mule and practice there.
4. Along with #3, take it further. Appreciate the kit for what it is, look at my skill set objectively, and do the best job I can with construction and painting to do the kit justice. That means careful parts preparation, good construction methods, test fitting, and painting this thing as best as I possibly can. All while not sweating the small stuff. I get too hung up on small, stupid things that don’t matter. That needs to change. This build will change that.
Once I had established that, I was off to the races.
Here’s the references:
And here’s the work I’ve done so far:
...I’m done using PE IP’s and IP decals if I can help it. I have grown to hate both for various reasons. It pleases me more to paint my own, and detail them myself. Here’s the IP:
And the rest of the cockpit as it was coming together. Under harsh light that green blares. Under soft, normal light, it darkens up a lot. Very interesting:
With harness and seat added, and installed inside the fuselage mock-up:
And here she is on my new jig:
Cockpit needs another coat of flat clear. And some miscellaneous stuff needs done on the install before sealing the old girl up. After that I’ll either paint the gear bays, or get started puttying-up the panel lines on the wings. I’m competent to do that.
This is a great airplane. I’ve really come to like the Pony. If you’re interested in reading about my particular subject and it’s backstory, you can read more here:
http://www.laituk.org/P-51%2043-6623.htm
Re: 1:48 P-51B “Spare Parts” (Tamiya Kit)
Well, that toots tootsie rolls. Had a really great reply coming and the net timed out and lost it.
Suffice it to say, don’t disparage you prior stuff too much. From where I sit, it was amazing in both skill and detail. Sometimes it is good to move to a subject that grabs you and you are certainly doing this kit justice! Love the harness and IP. Keep it coming.
Lyle,
Thanks buddy, I appreciate that.
Bro, you should’ve seen how I botched painting the afterburner nozzle on my 1:72 F-16! Oh man what a spectacular failure. Oh man...
As to Marga’s engine, I’m redoing the plumbing out of wire as Carlos suggested. Connecting the pieces together will suck, but it won’t be brittle like the stretched sprue was. I’m sure glad I’ve been taking my time with her and didn’t actually glue the engine block in there. I left it removable just in case there was anything I’d like to change later on.
Anyway, I get what you’re sayin and I appreciate it. Marga is safe while I work on this bird. And as to my F-16, the nozzle will be redone in time.
I understand. I think I have learned as much or more from the mistakes I’ve made.
Looks good, Kenny. We get all wound up when we're building them but they all deserve love when they get to the display case, where we can't see all those little details that bothered us so much. The camera is our enemy!
Mr. J,
Yup. Ans that’s why I’m trying not to sweat the small stuff anymore :-D
And here I thought you were talking about you had P-51 Mustang spare parts. Come to realize you were talking about the Mustang called "Spare Parts"''' :headslap: :giggles:
The office looks great but did you know the P-51B Mustang floors were made of wood sometimes painted cockpit green? No kidding... I found out that by accident...
I had no idea. I was aware that this kit didn’t come with the “correct” floorboard, but here’s how I rationalized it- after the crash, whilst rebuilding the aircraft, he couldn’t source a new plywood floorboard to cover this metal sub-floor HAHAHAAA HEy! IT COULD’VE HAPPENED!
I'll buy it! Sounds reasonable to me, but I like Brussels sprouts.
Handiabled
Post by Handiabled »
Looks great so far! Great to see you found your way back again. I imagine that everyone here has had more than one “what the #*%= did I do “ moment on a build. Your work is a lot better than you give yourself credit for. I’ll be watching for more!
