SH 1/32 Tempest MK V
I believe all things Hawker, prop or jet....This GB is kindly being moderated by Mr. John Eaton (jeaton01)
Paul
Post by Paul »
I have built this kit before and I think I figured out how to sort of navigate myself around the issues that the kit poses. The last time I used the Barracuda cowl and prop set and it came out OK.
This time I am going with a mostly OOTB build Using a resin seat and 3d printed seat decals.
One of the most annoying issues is the kit cowling fit so I decided to add the cowling halves first to the fuse halves and see if I can find a fix. This is what I found.
The lap joint the is the assembly was not flush mounting. I then filed and cut away the offending area of the entire joint and was able to pull it down more closely to where it should be.
After I had the all curedI went to the next step and started assembling the pit and the inside walls. I sprayed a coat of aqua gloss and did some washes.
Ill do some more to the pit and get it finished in the next few days. I am taking this slow.
By the way, Ill drop a couple of pics to show what my previous model looked like.
Thanks for looking.
Re: SH 1/32 Tempest MK V
Very nice work in the cockpit so far! And the problem solving with the fit of the cowling looks like it will improve things quite a bit in that area.
The last Tempest came out gorgeous, so obviously this project has to end up looking at least that good.
Paul
Post by Paul »
I sure hope that you are correct, Carlos.
Carlos is right about that last Tempest. That thing is drop dead gorgeous Paul. :shoutout: :shoutout:
That Tempest is a bad girl indeed, Paul. I often wondered if they scream in a dive along with the Typhoon as the Stuka does. I mean those wide mouths must give out some sort of roar in a dive.
I really need to get me a Tempest kit in my stash. :bag:
looking good! I'm interested in knowing more about these 3d printed belts.
BlackSheep214 wrote:That Tempest is a bad girl indeed, Paul. I often wondered if they scream in a dive along with the Typhoon as the Stuka does. I mean those wide mouths must give out some sort of roar in a dive.
It’s gonna make some sort of noise due to the oil cooler. The Stuka made its distinct noise due to having sirens installed on the wheel spats as a psychological warfare measure. Later models of the Stuka no longe had the sirens, and sounded more typical.
Paul
Post by Paul »
I chose to really take my time with the pit before I cemented it into the fuse half. I only have two pics so far but I plan on getting the whole fuse sewn up today sometime which will be sometime after I do the snow removal and since we are expecting 8 to 12 inches more that might be going on for a couple of days. To me the cockpit assembly is pretty fiddly so I just let parts cure before I continued on to the finish. I was going to use the 3d seat belt decals but I chose the Eduard pe set over them because the Eduard set looks more scale to me where the decals looked more for a 48 scale subject instead of the 32 that they are.
Nice work, Paul.
Return to “The Storms of the Hawkerlypse”
