1/72 MPM Focke Wulf Fw189 A2
sergio
Post by sergio »
the Fw189 I'll do is the V7 +1 E did not find the W.Nr but if I had a photo that says it is the period when the British began incursones to stop the production of nickel in Petsamo to German armored industry. belonged to the plane Ausfkzlärungseinheit 1. / (H) 32 based on Petsamo, allegedly destroyed in raids of British but I have not been able to confirm the fact.
It might be W.Nr 2261, destroyed by bombing on 2nd July 1942. when he began raids RAF on German targets fell victims of these raids several fw189 so I could read but no clear expecifican serial of each plane and I already happened several times that the plane was another serial so if you do not have to certify it as a possible not claim anything.
so what I started:
as always with this brand has been making lace and checks so see where he has to work to fit well
Re: 1/72 MPM Focke wulf FW189 A2
Now there is something you do not see very often, I like that.
yep, it is not one often shown. Looking forward to seeing this one!
Adam
Post by Adam »
Man you are a glutton for punishment! :P Can't wait to see more.
sergio
Post by sergio »
thanks sirs,
the main thing I am from airfix, I started building model airfix and reach get almost the entire catalog of their models, it's masochism, I know, but it is something greater than me has many fond memories with my grandfather and airfix.
Man, as much as that ... I like to make models rarely seen and almost always these aircraft fall on brands like this that have magnificent details but still have to refine lace pieces, make a Tamiya or Hasegawa can also happen it's just harder to find.
CallSignOWL
Post by CallSignOWL »
holy giant gaps, batman!
you sir, are braver than I.
sergio
Post by sergio »
work and more work after caulking and sanding the plane is almost ready
but still has work ahead
That are a lot of styrene shims you have to use. But it is often better them using putty. Good going on all the work.
lawdog114
Post by lawdog114 »
Nice work..
Joe
Re: 1/72 MPM Focke Wulf Fw189 A2
A rarely seen build. Good job on the interior and gap filling!
