Civil War Messerschmit | Academy | 1:48
CallSignOWL
Post by CallSignOWL »
I wanted at least three kits ready to go before I broke out my airbrush, and so I reached in teh the stash...and grabbed THIS
Nothing fancy, just OOB. And of course, things open with the cockpit. Very nice detail here!
Things quickly progressed from here. In almost no time at all, I had me an early -109
the only part of the kit I had fit issues with is the nose insert. It was just too short! A couple strips of plastic lifted things up.
Primed and ready for paint!
all painted up
Paul
Re: Civil War Messerschmit | Academy | 1:48
Post by Paul »
Very good start. Are you doing the box art scheme?
scorpiomikey
Post by scorpiomikey »
Very nice, you should crack out the airbrush more often, you look to be a bit of a dab hand at it.
CallSignOWL
Paul wrote:Very good start. Are you doing the box art scheme?
Ill be doing this one, actually.
CallSignOWL
scorpiomikey wrote:Very nice, you should crack out the airbrush more often, you look to be a bit of a dab hand at it.
Im guessing that means good? LOL
scorpiomikey
Yes, sorry, i forget you guys don't always speak English the way we do here.
be a dab hand (British & Australian)
to be very good at an activity (often + at ) You should get Ann to have a look at that. She's a dab hand at getting stains out of clothes. (often + with ) I hear you're a dab hand with the paintbrush. (= you are good at painting)
CallSignOWL
thanks for the linguistics lesson scorp :book:
sergio
Post by sergio »
one of the house !!!
I can put some info here, some pictures of the plane and the pilot of the plane as well as his successor at the end of his term in Spain
in summer 1938 He is the man with the cane
the plane just arrived in Spain in the field of "la maestranza" of Sevilla
the plane in the summer of 1938 with the emblem in the circle and painted,
the two spinners with decorations that tube
finally, the plane after being relieved by Walter Grabmann
Image.
encourage the airplane at the moment is a thousand times better than the best of my planes
Those are some interesting pics Sergio!
I like the camo Owl. Also, the idea of using plastic shims instead of filler on the nose is very good. However, I would suggest to use styrene, that is easier to blend in and attach then the transparent plastic that you used. Styrene can just melt in if you use a liquid glue, then there is no need for filler.
CallSignOWL
great stuff sergio!
