CB's Monogram 1/48 P-51D Build
I guess I'll follow Lyle's Lead at start a separate thread. So let us review again ! :whistle:
The Kit:
The Parts:
The exhaust (It needs to be modified to be installable from the outside).
The lower rear fuselage is a mess of sink marks, flash and steps. It's best to remove the gear doors and poorly represented details the sand and file everything smooth and start over with a clean slate:
The tail wheel mounting holes are best modified to allow wheel to be inserted after fuselage is joined (and probably after painting and decaling is done as well!)
What can I say.. I've gone saw happy. Just because you can do it, means you should do it.... wait, that does not sound right... :hmm:
Re: CB's Monogram 1/48 P-51D Build
Looking great man! Keep it coming!
I saw what you did here!
That's why I take pictures... :giggles:
Thanks Duke, that is my intention!
Glued the wings. Started some cockpit painting...
I like it!
