Point Du Hoc
SteveSki
Point Du Hoc
Post by SteveSki »
Point Du Hoc
This is the wonderful set: RM1602, US Rangers, Point Du Hoc, vignette from Reedees Miniatures in 1/16th scale. These resin figures and base are created and sculpted by Steve Reedees. This set can be found at: https://sites.google.com/site/reedeesmi ... /116-120mm
When you open the box the first thing you see is every parts set is carefully packaged and separated according to each figure within the set. The casting is incredible, and I’ve never seen anything but top-quality work coming from Reedees Miniatures, quality control is top shelf!
Call me biased, but I’ve worked with several of Steve’s figures, from 1/16th to 200mm, including weapons kits from the armory on his website. The kits have always been reliably well done, clean and crisp, requiring minor clean-up. This makes a painter like me very happy. BTW, the weapons are incredibly well done, too, and accurate. Did I mention that already?
Seeing this set makes the painter in me want to get after it and get to “sniffin some paint and gluin my fingers together”. Sorry, I had to include my personally coined phrase on this set, it’s that good. Let’s just hope I can do it justice. So, here we go, let’s get er done!
As we get further along, I’ll add a few pics of the rock wall section. Wow, very well done and minor slag as can be expected, but nothing needing any serious adjusting or heavy filing. I’ll break each figure down so you can see the quality of the sculpting and casting.
Quick note; I ran a test fit on the two adjoined figures within this set, spot on fit. This is going to be a fun run from all indications, working on a very welcome planned and carefully sculpted set. Ruck On, Bby!
More to follow, mue pronto, and thanks for watchin. Cheers, Ski.
Re: Point Du Hoc
Looks like a great kit. Right on to the next one eh?
Re: Point Du Hoc
Rudder’s Rangers! This is gonna be a great one!
SteveSki
Re: Point Du Hoc
Post by SteveSki »
Tanks, guys. This is a very clean set, very clean.
SteveSki
Re: Point Du Hoc
Post by SteveSki »
Getting Started
The first thing you’re going to notice from this set is how clean the cast is and the lack of serious seam work required. I only found a few areas requiring attention and most of those were found after the primer coat.
When you get a set of figures like this the clean-up process moves quickly and the fun begins much sooner. After all, we know there will always be some clean-up, but what we’re really after is the fun of painting. This is pretty standard for Reedees Miniatures. I am never disappointed, and the craftsmanship is incredible.
The climbing Ranger fit right into his slot and hung there without any form of aid, meaning, he is very well placed. The other two were temporarily set in place so I could get a general idea of how this set will end up on the base.
After the general clean-up I began test fitting the arms, hands etc. The way Steve worked these figures is impressive. The arm fits snuggly and fits well, avoiding the need for any putty or filing. You will also notice the support hand for the Sgt. fits into its sleeve and tucks right under the Tommy gun fore stock naturally. I can see there was a heck of a lot of time taken to make this grip look realistic. Once again, the craftsmanship is glaring on this set. You can see from these photos just how well the arms lock into the shoulder. There are also keyways and pins that assist in the alignment, another great plus.
The set is now ready for some primer and a final review of each piece to catch any seam lines or small casting holes. This process was quick and easy, not much had to be done.
Base Stand Set
For the base I pilfered a scrap piece of Rustic Hickory from the shop and cut it to size. I sanded it and pinned it to receive the base, then later covered it with blue masking tape to avoid scratches and dings. There was one small rope section that broke off which was replaced with twisted copper wire to match.
Primed and Base Coated
After a good coat of Floquil Primer and inspection I moved right on to the base coat. As you can see from the photo, I used Tamiya paints and made a few custom colors for web gear and other parts.
As per my standard process I will begin with the heads and move onto each figure in order. So, let the fun begin!
More to follow soon and thanks for watchin. Cheers, Ski.
Re: Point Du Hoc
Great start on this. It looks like you made a mix of Tamiya Khaki with Khaki Drab for the HBT fatigue uniform color?
SteveSki
Re: Point Du Hoc
Post by SteveSki »
All Tamiya, yep. Thanks, Carlos.
Re: Point Du Hoc
SteveSki wrote: ↑Sun Nov 12, 2023 7:04 pm All Tamiya, yep. Thanks, Carlos.
I own an original set of those HBT fatigues, and your mix is pretty damn right on target! What is your ratio of XF49 to XF51?
SteveSki
Re: Point Du Hoc
Post by SteveSki »
Oh man, ratio by sight, no numbers, HA! I took ref pics from the net to get a rough guestimation. I've never worked by ration, it's easier for me to visualize the tones rather than play the numbers. Ha, I always lose at cards anyway, or poker, the numbers are against me, HA!
SteveSki
Re: Point Du Hoc
Post by SteveSki »
Let’s Face It, Again!
Getting started on the faces is always a re-learn process for me, regardless of how many faces I’ve paInted in the past. It may sound like a pain in the hinny, but I’m used to it and expect it. This process is not a negative approach, but what I would call a warm-up session. So, I pick the likely candidate to be the ginny pig, or “crash test dummy,” and off I go. It’s always “crash and burn” on the first paint fling, so crash test dummy would be the appropriate term, HA!
My mix for the flesh work is very simple, as you can see from the palette, Windsor & Newton Burnt Sienna and Titanium White. To the left side of this string of tones I also have a small run for Brunt Umer and another for Raw Umber. These two darker tones are used sparingly to give depth where needed, such as above the eyes, under the lower lip, under the chin, behind the ears, and the inside of the mouth. Very rarely will you actually see a solid black tone in real life, so I rarely if ever use it on my flesh work. Working each shade from dark to light on the palette I now have the basic mixes for the flesh work. Time to fling some paint!
With the colors laid out on the palette I run an initial pass with a very light and very thinned shadow tone in all the deep recesses, then come back and lightly spread, or fan, those out with a damp brush. This process really needs to be very thin and light or they will all become crash test dummies in a hurry! I use a mix of Ivory Black and Raw Umber. After the initial shadows are placed it’s time to work the main flesh tones.
I didn’t take any sequential photos of the process, because I really don’t like to disrupt the momentum once I get into the grove, it kills the flow. I have taken SBS sequential photos in the past on prior builds, so I won’t be doing that on the facial work here. I will again refer to Daria Callie’s oil painting videos for quick reference.
https://www.youtube.com/channel/UCyGgRL ... 9ZS5DaqMOQ
Yes, Daria works on canvas and we work three dimensional, but I find the concept is the same for oils. I found that by following the basic concepts of her approach I have eliminated a lot of the “heavy oiling”, or over painting, which can lead to a blotchy appearance if not corrected. If this video helps, good deal, and if not, forget about it.
There is still quite a bit of work to be done on both of these faces, such as feathering in more details, refining certain areas, but the initial passes have been made and the base tones will need to set up and dry for a bit.
One handy tool in the model bunker is the trusty Oven Cleaner. As you can see, this fellow is getting his bath for a re-do. Actually, this will be his second bath. It’s not uncommon to make three runs before I get back into the swing of things.
