Another batch-o-birds
Fermis
Post by Fermis »
On and or near the bench right now...(in no particular order)
1/72 Hasegawa SBD w/ much A/M goodness!
1/72 AZ Models TBD (will be doing some scratchwork on this one!)
1/72 Dragon F4F w/ True Details pit
1/72 Dragon F6F (also an Eduard F6F, not pictured)
Fermis
Re: Another batch-o-birds
Post by Fermis »
Started with the SBD.
True Details pit (flash from my camera makes the green look way cartoony-er-ish than it really is)
Quickboost exhaust beat the molded in kit exhausts!
Fermis
Post by Fermis »
Broke out the F4F as a little side project, to go along with the SBD.
True Details pit...
Dragon instructions.... :scream:
...NO pit....NO engine...NO puting the gears in place...etc
In my haste to get this thing closed up....
That little window is supposed to go in that hole...from the inside, before closing it up...... :Bur2:
There is a small amount of room, to go in through the pit, but I know I'da made a mess with some glue.
Then I thought...just glue em in backwards and sand down the excess....too much curve, no joy.
Gonna have to make my own...
Carved out a "window" in a piece of scrap, (just slightly larger than need be).
Bent the plastic over a pin vice (for the curve)...heated up some clear sprue and pressed it into the "window".
A little bit of carving and trial-n-error...parts CA'ed in place...
Snipped off most of the excess, then used a grinding drum to grind them down close...
Then used a finer grinding bit to get them even closer...
Sandpaper to finish them off, followed by a good polishing.
...a lot of time spent, for what should have taken about 20 seconds if I had put the kit parts in when I should have.
Fermis
Post by Fermis »
As they sit now...major assembly done, both have Quickboost stabillizers.
Hellcats coming up next!
Look like you are recreating the whole us navy air fleet in one go. I like the creative solution for the windows.
Nice recovery. What do you heat the clear sprue with?
Fermis
Post by Fermis »
LyleW wrote:Nice recovery. What do you heat the clear sprue with?
Hot heat!!! :chair:
:tease:
Who'da thunk....a regular household candle would be an essential modeling tool?!!!
Okay...... :Bur2: All I have is cold heat. Have to run to the store!
CallSignOWL
Post by CallSignOWL »
gonna have yourself a whole squadron there!
Im envious of all our goodies!
and nice save on teh windows. I once put a fuselage together but forgot the cockpit!! Whoopsies!
Manny1943
Post by Manny1943 »
:yikes:
Wow...looks like preparations are being made to take that Judy out that you just built !!!
...this site is lucky to have such a prolific and skilled modeler posting on it!!! :bow:
Looking forward to seeing what schemes you have planned...
