Testor's 1/72 B-2 / F-117 Combo
Re: Testor's 1/72 B-2 / F-117 Combo
You would be welcome any time! I have two glasses on the counter...and a straw.
we have those, too! :yipee:
A little progress! I cleaned up the bench. I loves me some red bondo glazing and spot putty!
Considering where it was, this may turn out ok....
Threw some more liquid styrene at it. I've found that 100 grit sandpaper will make quick work of the excess, followed up with 220 and then finer as we go. Detail? Panel lines? We don't need no stinkin panel lines!
I wouldn't go that far, Jim! Surrender is always an option - followed by uncontrolled flight into a hard surface.
My half-baked (pun intended) dryer-helper-outer.....right after this, it came crashing down. No damage to the beast.
scorpiomikey
Post by scorpiomikey »
No damage? Is that because its more bondo than plastic?
:D :yahoo: Mikey, I'm not sure. It could be, though. In a couple of spots, the secret, government approved, special radar absorbing, gap filling material "cracked"....but not bad. Nothing another tube won't cure.
BsYamato
Post by BsYamato »
seems like an amodel have better junction than this B-2 kit :yikes:
Never surrender !
