Tamiya P-38
Re: Tamiya P-38
LyleW wrote:
Thank you, Stuart. Finish that puppy, then....
1). CA adhesive
2). Roof of your car.
My work here is finished. You’re welcome.
:grin: Well that's certainly a thought.... :hmm:
Re: Tamiya P-38
To paraphrase Rene Descartes (Descartes before Deshorse)
"I think, therefore I will probably screw it up"
I chose not to add the superchargers at this point, since it would be a nightmare to mask them off later. I've also left off a couple of other pieces as well.
Started the right boom assy this morning. Somewhat fiddley, but even at that, the pieces all fit perfectly when you got them in position, and stayed put while you applied your cement of choice. I was amazed. But there is a caveat for me. When there are more than one assembly sequence that is the same (or, two or more), the first usually goes swimmingly and the second goes in the dumpster. I will have to be careful with this one.
Time to go fix lunch.
Re: Tamiya P-38
Just take your time Lyle, I'm sure it'll be fine!
Looking good thus far! :shoutout:
Re: Tamiya P-38
Great progress Lyle!
Re: Tamiya P-38
Good show old man! Carry on. :grin:
Re: Tamiya P-38
Stuart- Time I got! I am going at a much slower pace. Lotsa pieces!
John - Thanks!
Gary- Thank, man.
Re: Tamiya P-38
Looking good, Lyle! :shoutout: :shoutout: :shoutout:
Re: Tamiya P-38
Thanks, Tom. Quite an interesting kit.
Re: Tamiya P-38
Progress is looking great Lyle! If the J superchargers are designed like the F/G you need to cut out that circle peg to get them to slide in later
Re: Tamiya P-38
Clint, thanks for the compliment! PM sent. Just tried them, perhaps Tamiya made a slight change? They dropped right in place! Winner, winner, chicken dinner.
