Border 1/35 Focke Wulf Fw190A-5 Nowotny Double Chevron
Re: Border 1/35 Focke Wulf Fw190A-5 Nowotny Double Chevron
John, what method did you use to "flatten" those tires? Those areas look very well done and quite consistent. :grin:
That engine is indeed a gem, and as mentioned before, would look great displayed alone on a stand. :bow:
Thank you, Gary! I used coarse sandpaper (320#) taped to a piece of glass from a photo frame. And then rubbed the wheel over the sandpaper, careful to keep the orientation uniform during each stroke.
More shots of the engine...
:shoutout: :shoutout: :shoutout: Man that engine looks good! Very realistic!
:wow: :wow: :wow: :wow: :wow:
Fantastic!
Thanks guys!
Playing around with cowling guns... I've drilled the cooling holes and added a wire.
The seat is finished with the 1/48 scale harnesses. The cockpit tub has been given a base coat of RLM 66 Dark Grey and chipped a little with hairspray but still needs more paint work.
Wow :bow:
Man that engine looks awesome!
What everybody been saying...
Brandons_Iron
Post by Brandons_Iron »
I love radial engines and this thing looks incredible. :bow:
BrandonK
