That engine is indeed a gem, and as mentioned before, would look great displayed alone on a stand.
Border 1/35 Focke Wulf Fw190A-5 Nowotny Double Chevron
- Gary Brantley
Re: Border 1/35 Focke Wulf Fw190A-5 Nowotny Double Chevron
John, what method did you use to "flatten" those tires? Those areas look very well done and quite consistent.
Thank you, Gary! I used coarse sandpaper (320#) taped to a piece of glass from a photo frame. And then rubbed the wheel over the sandpaper, careful to keep the orientation uniform during each stroke.
More shots of the engine...
Thanks guys!
Playing around with cowling guns... I've drilled the cooling holes and added a wire.
The seat is finished with the 1/48 scale harnesses. The cockpit tub has been given a base coat of RLM 66 Dark Grey and chipped a little with hairspray but still needs more paint work.
Man that engine looks awesome!
What everybody been saying...
- Brandons_Iron
I love radial engines and this thing looks incredible.
BrandonK
