Lindberg Tuna Clipper
Re: Lindberg Tuna Clipper
Stikpusher wrote: Tue May 12, 2026 8:04 pm
speedgraflex wrote: Tue May 12, 2026 4:07 pm :shoutout:
That looks grrrrreat, Lyle!
Where a Tony the Tiger when you need one? :hmm:
Lyle, the red looks perfect! Well done! :shoutout: :shoutout: :shoutout: :shoutout: :shoutout:
Thank you, Bruce, Carlos. The red is much better.
That's a nice shade of blue!
Thanks!
I need y’all’s hep.
See below. One side worked. One side didn’t. I painted a contrasting color for the depth markers, then over painted in the hull color. Lightly sanded.. anyway, I need 1/100 (1/97.6 someone online calculated) hull numbers in black and white. I may be able to make the black, but not the white. I’ve found some in white that are different scales.
I already sanded the bad side off.
Hmmm. I already had a solution using what was there, then I read that you removed the decals by sanding. I have to rethink now.
Maybe you can find a set of decals online. That’s what I’d try first. Or contact Lindberg about sending you a set.
I’m trying to suss what happened. Maybe you need to polish the surface with a microfiber cloth gently, to remove a rough finish. It’s hard to tell from the photos what happened, but I would definitely want to make sure the entire hull surface is smooth but not glossy. I wouldn’t add gloss on top of Rust Oleum. Hand polishing ought to give you a smooth surface. Something I’ve played around with which comes from my Dad is using Johnson hard floor wax as a surface polish.
speedgraflex wrote: Wed May 13, 2026 3:13 pm Hmmm. I already had a solution using what was there, then I read that you removed the decals by sanding. I have to rethink now.
I had a thought, then I remembered I sanded it all down.
I worked them very lightly.used a finenemory board because it was stiff. The Rustoleum is gone. This is automotive primer, Tamiya rattle cams. If I have to print, I think a dark gray would work.
keavdog wrote: Wed May 13, 2026 3:38 pm Something like these work Lyle?
https://www.ebay.com/itm/196333957111?c ... =view_item
Hmmm, hadn’t thought of that. I’ll have to measure the size of what’s left.
What is molded on the bow looks to bow looks to be 0.07” or 1.7 / 1.8 mm. So something like that might work.
Atlantic Models is a great resource!
https://atlanticmodels.net/decals.html
Thanks, Bruce.
I’ve ordered some in blac k and white
