Cross Kit General Lee....ish-Completed-12/28
Re: Cross Kit General Lee Build-Decals-07/19
Thanks guys!
Today was Gloss Coat day soooo......I broke out the Testors "Wet Look" Clear ….the ONLY way to go for supreme gloss finishes in my experience. I dispensed it into a paint jar, let 'er gas out for about 5 minutes while I was removing whatever dust particles I could find on the body and went to work.
I spray all the bottom areas first and work my way up the sides and onto the roof, decklid and all the upper facing areas with a mist coat at first and then open the needle up and go "full bore" with a nice wet coat without taking it too far to avoid runs.
Couldn't be happier with the results. Now...……..to let it cure out for a couple of days before a nice wet sanding and polishing.
Re: Cross Kit General Lee Build-Gloss Coat-07/20
Outstanding...Amazing look.
LyleW wrote:Outstanding...Amazing look.
Thanks Lyle!
I wanted to play around with the wheel / tire and stance today. Actually I should've done this step first with an unpainted body but.....I just so happen to have a Revell Superbird kit that has pretty much the same dimensions as this kit does. I robbed a set of Monogram / Revell 1/24 scale street tires that have the perfect dimensions for such a big car as the Charger and used the Eckler Corvette wider wheels in the back and the skinnier OOB MPC ones in the front. I'm kind of likin' this.... :hmm:
pzl66
Post by pzl66 »
mustang1989 wrote:Image
Messerschmitt 109 Addict
LOL!!! Thanks Kevin!
Holy crap!! That's just incredible. :shoutout: :shoutout:
Thanks Mike! You a believer in Testors Lacquer yet?
:hmm: We'll see. I'm not real thrilled about decanting the paint.
