Possible subject: a yellow tailed Polikarpov I-153
Yellow Nose, Green Nose, Blue Nose, Red tails, Yellow Tails Checkered Nose, etc...
Basically, any Allied aircraft during WW2 that sported any type of Colored or Checkered Noses and/or Tails.
I think this ticks all the boxes:
- allied
- wwii
- yellow tail
Re: Possible subject: a yellow tailed Polikarpov I-153
Now that's cool!
I’d say that it does check all the boxes.
Great choice, Borg!
BorgR3mc0 wrote:I think this ticks all the boxes:
- allied
- wwii
- yellow tail
Good choice Borg!
These Chaikas are truly special birds!
Any idea on what front your yellow tailed seagull was operating ?
I'll pay attention for that build
I am doing some more research on this bird. And the information is sketchy.
Most sources say it is yellow tailed red 6. But according to ICM it is a white tailed red six.
And some sources say it is an aircraft 72 IAP from the North Fleet airforce based at Vaenga. But other state it is from the 8 IAP based at Sebastopol (because there are apparently no mountains a Vaenga but there are at Sebastopol, see the second picture). So it is all a bit vague and I will have to make some judgment calls on this. I did find a few very nice pictures of the specific aircraft.
I can leave the gear doors off, need to make an antenna, no stores under the wing, use early red stars and a reflection gun sight (not a telescopic one).
Those have graceful lines!
More research: there are a few flaws in the kit. Some are easy fixes (no panel line on the right side of the rudder ) others will take a bit more work. Most glaringly the lack of exhaust pipes, such a prominent feature of these aircraft. There is a very good article on Hyperscale that documents everything.
http://www.hyperscale.com/2016/reviews/ ... ewmd_1.htm
I started some preliminary work. I made a pattern for a better seat using parts of the I-153, a I-16, PE buckles and stretched sprue. I also made a pattern for exhaust pipes. I am going to cast these in resin.
I also worked on the fuselage: opened up a few holes, made a rudder line on the right side (ICM forgot that!) and a hole in the rudder where a bar needs to come.
Return to “Yellow Nose, Green Nose, Blue Nose, Red Tail”
