Carlos, I really really REALLY want to thank you for following along. I also want to thank Blacksheep Tom and John Eaton as well. I want to add that all viewpoints matter. I am using the WnW instructions (not the build process or the detailing) but the instructions which are available online as a PDF as information. One of the main reasons I removed the fuel filler rims was because that was what was done as a field modification. The model building reason was simply because the circular impressions were off-center and interfering with the shaping process to remove the seam ridge. I am attaching the relevant page from the WnW instructions:
Cut-Down Decking
I find the explanations in all of the WnW kitsets to be most useful!
Tomorrow I will hopefully take the fuselage (which I have prepped) out on my apartment balcony and give it a quick squirt of light gray primer. I know I plan to use Mr Surfacer's 1500 white on the wings but I think I will start with a quick check in with gray (or is it grey with an E?). Maybe my best laid plans will change to light grey/gray primer overall due to the amount of sink marks, injection pin marks, flash and fit issues that need to be addressed.
